Lesson Objective: By the end of the lesson, students will be able to compare and identify the largest object from a set of four items based on size.
Which is Smaller?
Level: Junior Infants
Strand: Early Math Activities
Strand Unit: ComparingĀ
Lesson Objective: By the end of the lesson, students will be able to compare and identify the smallest object from a set of two items based on size.
Which is the Smallest?
Lesson Objective: By the end of the lesson, students will be able to compare and identify the smallest object from a set of three items based on size.
Which is the Biggest?
Lesson Objective: By the end of the lesson, students will be able to compare and identify the biggest object from a set of three items based on size.
Spot the Rectangle
Strand: Shape & Space
Strand Unit: 2D Shapes
Lesson Objective: The child should be enabled to identify, sort, and colour the rectangles from a page of various 2-D shapes.
Spot the Square
Lesson Objective: The child should be enabled to identify, sort, and colour the squares from a page of various 2-D shapes.
Find Me One
Strand: Number
Strand Unit: Counting and Numeration
Lesson Objective: The child should be enabled to trace and write the number one, count different sets of objects, and colour in the set that has one item.
Dotty Addition
Level: Senior Infants
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to add numbers using counters / dots as visual representations.
Find Me Two
Strand: Number
Lesson Objective: The child should be enabled to trace and write the number one, count different sets of objects, and colour in the set that has two items.
Counting Cards
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to mentally add two amounts quickly on card faces.
Shape Addition
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to add two sets of shapes and determine the total number.
Shape Addition II
Strand: Number
Shape Addition III
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to add two sets of shapes and determine the total number. They will also write the corresponding number sentence to match the picture.
Find Me Three
Level: Junior Infants Strand: Number
Lesson Objective: The child should be enabled to trace and write the number one, count different sets of objects, and colour in the set that has three items.
Dicey Addition
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to add three numbers shown on dice faces.
Find Me Four
Strand: Number
Lesson Objective: The child should be enabled to trace and write the number one, count different sets of objects, and colour in the set that has four items.
Find Me Five
Strand: Number
Lesson Objective: The child should be enabled to trace and write the number one, count different sets of objects, and colour in the set that has five items.
Addition Maze Junior
Strand: Number
Lesson Objective: By the end of the lesson, students will be able to solve addition questions to navigate through a maze from start to finish.
Addition Maze Senior
Strand: Number
Extend the Pattern
Strand: Algebra
Strand Unit: Extending Patterns
Lesson Objective: By the end of the lesson, students will be able to identify and colour the next shape in a given pattern.
